				Measuring THD
				Posted: Sun Dec 11, 2016 12:56 am
				by vincer
				I have externally looped the output of the 2810 to the input.  The THD  measures between .2 and .3 out to the third harmonic at 1 KHz using a Hamming Window.  If the native THD of the instrument is over .1 % ,  How can I measure the THD of low THD amplifiers?
				Re: Measuring THD
				Posted: Mon Dec 12, 2016 9:54 am
				Thank you for your questions.  Kaiser 6 window function is recommended for THD measurement. The loopback THD will be a little better if Kaiser 6 window is used instead of Hamming window.
More importantly, VT DSO-2810 is not designed to measure low THD as indicated by its own THD figures in the specifications.
