I don't find a way to load the generator parameter with a WAV file.
In the Automation server manual (v1.7), I read
nWaveformB
Waveform for Channel B:
0: None
1: Sine
2: Rectangle
3: Triangle
4: SawTooth
5: WhiteNoise
6: PinkNoise
7: MultiTones
8: Arbitrary (via Waveform Library File)
9: MLS
How to set it to "WAV" ?
If that doesn't work, that means that I can't call the function SetSignaGeneratorParameters
which is annoying, because I need it to set the output level...
Automation: How to load WAV in Generator ?
Re: Automation: How to load WAV in Generator ?
OK, it seems I figured it out by myself.
I just call the function SetSignalGeneratorParameters with both nWafeFormA and nWafeFormB set to 13.
Great! You have figured it out by yourself
LoadPanelSettingFile() can also be used and is more generic.
Yes, indeed.
"LoadPannelSettingFile" doesn't work to change the level.
But it sets the filename.
