To save panel settings, specifically for CCIF3, you'll likely need to save a configuration file within the software or application that uses those settings. This typically involves locating a "Save Config File" or similar option within the application's interface. The saved file, often an XML file, will then store your current settings for later use or for transferring to other systems. The one,
monkey type solution that is known to work is to use Clean Flight or Beta Flight (command line stuff at very bottom of their Configurator "FLASH_ERASE" command to ...I just made a really cool looking panel layout and I would like to copy the panel layout to the Xubuntu machine, I was unable to get the XFCE4 ...To switch off the instrument completely use the rear panel power switch (press side “0”). All settings remain stored and after switching power on again the ...The method of saving and recalling data with these registers is through the "SWAP CAL" soft key. The user may choose not to use the swap registers unless more ...
